MediaCentral | UX User’s Guide : Using the Sequence Pane : Editing a Sequence
Editing a Sequence
You can work with one of two sequences: a basic sequence or an advanced sequence (see Understanding Basic and Advanced Sequences). The following topics describe how to work with basic sequences and advanced sequences:
• Locking a Basic Sequence (Interplay | MAM)
• Performing an Insert Edit in a Basic Sequence
• Performing an Insert Edit in an Advanced Sequence
• Performing an Overwrite Edit in an Advanced Sequence
• Position Indicator Placement After an Insert or Overwrite Edit
• Performing a Replace Edit
• Enabling an Audio Track
• Using a Basic Sequence as a Source for a Sequence (Interplay | Production)
• Using a Basic Sequence as a Source for a Sequence (Interplay | MAM)
• Using Match Frame from Asset Mode to Add Media to a Sequence
• Undoing and Redoing an Action in the Sequence Pane
• Moving or Deleting Segments in the Timeline
• Adding and Removing Audio Segments
• Creating an Audio-Only NAT or SOT Segment
• Snapping in the Timeline
• Trimming Segments in the Timeline
• Using L-Cuts in the Timeline
• Splitting a Segment
• Adding Markers to a Sequence
• Inserting Video Dissolves (Advanced Sequences Only)
• Enabling Audio Scrubbing
• Modifying the Start Timecode
*Ancillary data that is contained in a clip is preserved when you edit the clip into a sequence.
