MediaCentral | UX User’s Guide : Using the Sequence Pane : Editing a Sequence : Adding Markers to a Sequence
There are two ways to add markers to a sequence:
• Add a clip or a portion of a clip that contains markers.
• Add markers directly to the sequence.
*Markers are a feature used in Interplay Production assets. For complete information about working with markers, see Logging Interplay | Production Assets and Creating Subclips.
Adding a clip that contains markers: Any markers that are contained within the In and Out marks are copied to the sequence when you edit the clip into the sequence. Copying markers with a clip is a “one-time copy.” If you lengthen a clip by trimming, markers that are included in the added part of the clip are not copied. If you shorten a clip by trimming, you remove any markers that are included in the trimmed portion. They are not restored if you lengthen the clip. To restore the markers, redo the edit. You can use Match Frame from the sequence to locate the original clip. See Using Match Frame.
Markers in audio-only clips: Markers are not added for audio-only clips, such as voice-overs. You can copy markers only from a clip that includes a video track.
Moving segments with markers: When you move a segment of a sequence that contains markers, the markers are also moved.
Adding markers in Output mode: If you are adding markers to a sequence in Output mode, saving in the Logging pane or saving in the Sequence pane saves both the sequence and the markers.
Switching modes in the Media pane: If you switch from Output mode to Asset mode, or from Asset mode to Output mode, the Logging pane switches to match the media that is loaded in the Media pane.
*If you set the Logging pane to display only those markers created by you, only your markers are visible in the Sequence pane. For more information, see The Logging Pane for Interplay | Production Assets.
