MediaCentral | UX User’s Guide : Using the Sequence Pane : Editing a Sequence : Moving or Deleting Segments in the Timeline
After you add assets to a sequence, you can rearrange them in the timeline. A portion of media that is contained on a track in a sequence is called a segment.
For an advanced sequence, after you have added a segment to the timeline, you cannot switch it to a different track. For example, if you drag and drop a clip into the timeline as a SOT, you cannot then select that segment in the timeline and drag it to another audio track. If the clip has audio on a channel that is not mapped to the audio track in which you insert it, you will not hear the audio when the sequence is played.
*If you want to change the track into which audio was inserted, you can use the procedures described in Adding and Removing Audio Segments.
To move a segment in a sequence:
1. Click the segment you want to move.
2. Drag the segment and drop it in a new location in the timeline.
In a long sequence, moving a segment to the viewable edge of the sequence (top or bottom for a vertical timeline, left or right for a horizontal timeline) scrolls the sequence in that direction.
To delete a segment from a sequence, do one of the following:
*Right-click the segment you want to delete and select Delete Segment.
*Click the segment you want to delete and click the Delete button in the Sequence pane toolbar.
*Click the segment you want to delete and select Delete Segment from the Sequence pane menu.
*Click the segment you want to delete and press Delete or Backspace (Windows).
Deleting a segment from the sequence does not remove the original source media from the server.
