MediaCentral | UX User’s Guide : Using the Sequence Pane : Editing a Sequence : Modifying the Start Timecode
In some cases you might need to change the timecode for the first frame of a sequence. This feature applies only to Interplay Production sequences.
To modify the start timecode of a sequence:
1. Load a sequence in the Media pane.
2. Click the Sequence Pane Menu button and select Modify Start Timecode.
3. Position the insert bar in front of the digit you want to change and type a new digit.
In the following example, the first digit is changed from 0 to 1.
To restore the original digits of the timecode, press the Backspace key or the Delete key.
4. Click OK.
To switch between drop-frame and non-drop frame for NTSC sequences:
*Type a semicolon (;) or colon (:) at any time.
