MediaCentral | UX User’s Guide : Using the Sequence Pane : Editing a Sequence : Using a Basic Sequence as a Source for a Sequence (Interplay | MAM)
Starting with MediaCentral UX v2.10, you can open an Interplay MAM basic sequence in Asset mode and use it as source footage for a basic sequence that is loaded in Output mode. When you load the sequence in Asset mode, editing controls such as Mark In and Mark Out are available through buttons and keyboard shortcuts.
Note the following:
• You can open basic sequences and audio-only basic sequences in Asset mode.
• When you open a basic sequence in Asset mode in the Media pane, the Media pane Actions menu only provides processes that are supported for sequences.
• If you insert the sequence open in the Media pane to the sequence open in the timeline, all segments are added individually to the timeline. The last segment is selected.
• A sequence cannot be added to itself. If you load a basic sequence in Output mode, and you open the same sequence in Asset mode, the sequence will be loaded in Asset mode, but there will be no timeline in the Sequence pane.
To edit material from a basic sequence to a basic sequence:
1. Locate the basic sequence in one of the following panes: Assets, Associations, or Search pane.
2. Do one of the following:
*Right-click the sequence and select Open in Asset Mode.
*Select the sequence, click the Pane Menu button, and select Open in Asset Mode.
The sequence opens in Asset mode in the Media pane.
3. Use the editing tools (Mark In, Mark Out, and so on) to edit the material you want into your sequence.
