MediaCentral | UX User’s Guide : Using the Sequence Pane : Editing a Sequence : Using Match Frame from Asset Mode to Add Media to a Sequence
If you want to use an advanced sequence as a source for another sequence, you can load the advanced sequence into Asset mode in the Media pane, and use the Match Frame feature to open the source clip for a particular frame. Then select media from the source clip to edit into the currently loaded sequence.
Because advanced sequences are not currently supported as a source, this approach is most useful when editing from an advanced sequence.
*You can also use Match Frame from Output mode. See Using Match Frame.
To use Match Frame to add media to a sequence:
1. In an Assets pane, do one of the following:
*Right-click a sequence and select Open in Asset Mode.
*Select a sequence, click the Pane Menu button, and select Open in Asset Mode.
The sequence opens in Asset mode in the Media pane.
2. Navigate to a frame in the material that you want to add to a sequence.
3. Do one of the following:
*Click the Pane Menu button and select Match Frame.
*Click the Match Frame button.
The master clip that contains the frame is loaded in the Media pane, with the matching frame displayed. In and Out marks are set to match the segment used in the sequence.
4. Edit the material you want into your sequence.
Related Topics
Using a Basic Sequence as a Source for a Sequence (Interplay | Production)
Using a Basic Sequence as a Source for a Sequence (Interplay | MAM)
