MediaCentral | UX User’s Guide : Working with Interplay | MAM Processes and Tasks : Working with Process Dashboards
The Process Dashboard pane lets you monitor all processes that you are allowed to see. This pane is different from the Progress pane, which displays only processes you created.
When you work with a process dashboard, you first define the dashboard context, which means you select the process source and the system that runs the processes, and then select the process type whose processes are to be displayed in the dashboard. You can save and work with more than one process dashboard at the same time. For example, you can have one dashboard that monitors processes of type MAM Export and another dashboard to monitor processes of type Export File. Saved process dashboards are shown in the Launch pane and can be opened from there.
The following topics provide information about the options you have when working with process dashboards:
• The Process Dashboard Pane
• Defining the Dashboard Context
• Working in the Process Dashboard Pane
• Saving and Opening Saved Dashboards
• Working with Process Groups
• Applying Filters
• Working with Diagrams
