Using Match Frame
The Match Frame feature lets you load a master clip that contains a specific frame of a sequence. This clip is called the source clip. You can use Match Frame to quickly load a clip from a sequence or subclip for additional editing.
Match Frame is available in both Asset and Output mode. In Asset mode, it is not enabled for master clips or advanced sequences. For more information, see
Using Match Frame from Asset Mode to Add Media to a Sequence.
To load a source clip for a specific frame of a subclip or sequence:
1. Navigate to the frame for which you want to load the master clip.
2. Do one of the following:
Click the Pane Menu button and select Match Frame.
Click the Match Frame button.
The master clip that contains the frame is loaded in the Media pane, with the matching frame displayed. In and Out marks are set to match the segment in the sequence.
