MediaCentral | UX User’s Guide : Getting Started : Understanding Layouts and Panes : The Menu Bar
The Menu Bar
The application’s menu bar includes the following menus:
• Home
Option
Description
User Settings
Opens the Settings dialog box with configuration options available for modification to non-administrative users. For more information, see User Settings.
About
Opens a screen with information about the product
• Panes
This menu lists the panes that you can open in the selected layout. For a list of these main panes, see Understanding Layouts and Panes. You are only permitted one instance of some panes within the user interface; however, you can open multiple instances of an Assets pane or Search pane. If a single-instance pane is already opened, the option representing that pane will appear grayed out in the Panes menu.
• Sign Out
Select Sign Out to leave the application and return to the sign-in screen.
Related Topics
Working with Layouts
Working with Areas and Panes
The Launch Pane
