MediaCentral | UX User’s Guide : User Settings
User Settings
You can access and modify user settings in the User Settings dialog box. To open the User Settings dialog box, select Home > User Settings.After you change a user setting, click Apply to save your changes.
The following table describes these user settings.
Settings Group
Setting
Description
General
Language
Controls the language used for the Web application user interface. Select the language you want from the drop-down menu.
Time Zone
Controls the display of dates and times. This setting is used by the indexed search in MediaCentral UX to display dates and other formatted data according to your selection. Select the time zone you want from the drop-down menu.
*The default time zone is set by the MediaCentral UX administrator in the System Settings.The default setting is “Use System Timezone,” which uses the time zone that is set by the computer’s operating system.
Date Format
Works with the time zone setting to display dates and times according to your selection. Select the format you want from the drop-down menu.
*The default date format is set by the MediaCentral UX administrator in the System Settings.For more information, see MediaCentral System Settings.
Password
Changes the password for your MediaCentral UX account. The new credentials are not in effect until you sign out and sign in again.
iNEWS
iNEWS Credentials
Sets the user name and password for access to the Avid iNEWS server. The user name and password must match the user name and password of an iNEWS account.
An option lets you set your MediaCentral UX user name and password to access the iNEWS server.
Sequence: Autoload Sequence
Determines if a script sequence is automatically opened in the Sequence pane and Media pane if its associated iNEWS story is opened.
Interplay | Production
Interplay Production credentials
Sets the user name and password for access to the Interplay Production server. The user name and password must match the user name and password of an Interplay Production account.
An option lets you set your MediaCentral UX user name and password to access the Interplay Production server.
Search Result Filter: Show only one representation for each asset found
Sets that only one representation (link) for an asset should be shown in the Interplay Production search results. Selecting this option can improve the search response time.
Search Criteria: Time Range
Sets the time range for an asset’s created or modified date when you perform a search of the Interplay Production database. The default setting is “Last 14 days.” A small time range can improve the search response time.
This setting is used for a search unless you specify a range using the search criteria Modified Date. For more information, see Conducting a Search.
Referenced Assets
Determines if referenced assets are displayed in the Assets tab. Referenced assets are assets that are referenced by another asset in the same Interplay Production folder, such as clips that are included in a sequence. The default is to hide referenced assets.
Media | Distribute
User Profile Name
Lists the Media Distribute profiles for publication types — for example, Twitter or Facebook. You can use this settings group to create personal accounts for Media Distribute publication.
Messages and Sharing
Email Forwarding
Enables or disables e-mail forwarding. When you use the Messages pane to send messages, e-mail forwarding allows you to receive messages at the specified e-mail address when you are not logged in to MediaCentral UX.
MOS
MOS: MOS enabled
(Chrome 44 and earlier only) Enables use of MOS plug-ins, such as the Avid Deko Select plug-in.
For more information, see Using Plug-ins and MOS Integration and the documentation for your plug-in.
Send to Playback
Preserve Overwrite State
(MediaCentral UX v2.7 and later) Determines whether the state of the Overwrite option in the Send to Playback Settings (opened from the Media Pane menu) persists between STP operations.
• If the check box is selected, the state of the Overwrite setting persists between STP operations.
• If the check box is unselected, the state of the Overwrite setting is reset to off after each STP operation.
*If the Overwrite setting is selected, an STP operation overwrites any sequence with the same video ID already sent to the playback device.
Sequence
Effects: Dissolve Duration
Sets the default duration for video dissolves that can be used to transition between segments in a sequence. By default, the duration is set to 20 frames. You can override the default when you apply a dissolve to a sequence.
Timeline: Enable paging
Enables a paging display during playback in the Sequence Timeline. This feature is useful when you are zoomed in to a sequence and you want to display the area around the position indicator. For more information, see Timeline Paging During Playback.
Thumbnails
Generate thumbnails in the background
If the Thumbnails pane is open, MediaCentral UX continues to populate the pane with images if the pane is in the background (open but hidden behind another pane).
To optimize performance, you can disable generation of thumbnails if the pane is in the background by clearing the check box.
