Media | Distribute User’s Guide : Media | Distribute : Publish to the Web
Publish to the Web
Media Distribute allows you to create your package and publish it to a corporate or broadcast Web site. The workflow for publishing your package to the Web depends on whether or not you want to start with an iNEWS story as your source. If you work from an existing story, you can automatically add text from the story to your package. If you start with media located in Interplay Production, you can use the text editor in the Web Story pane to create and modify your message.
When you publish to a corporate Web site, Media Distribute sends your package to your content management system (CMS). The CMS determines when the media package is published to your corporate Web page, depending on how your CMS has been configured.
For more information on using the Web Story pane, see the following topics:
• Publishing from iNEWS to the Web
• Publishing MediaCentral Assets to the Web
• Publishing MediaCentral Assets to a WorldNow CMS
• Publishing MediaCentral Assets to thePlatform
