Annotating Using Tags
The Logging pane provides a Tags column to add tags to the stratum annotation. Tags are values of properties that are not from type text, for example, date, timecode, or dictionaries. Tags help avoid typos, secure that terms are used consistently across all assets, and can be added faster than when typing manually. Which tags you can add to a stratum depends on the configuration of the stratum in Interplay MAM Datamodel Administrator.
You can display the Segment List in Tags view or in Grid view. Tags view combines all tags in a single column labeled “Tags,” as shown in the following illustration.
Grid view displays a separate column for each non-text property to display its tags, and the label set in the data model for the property is used as column header, as shown in the following illustration.
For a list of keyboard shortcuts you can use when working with tags, see
Logging Pane (Interplay | MAM) Shortcuts.
Related Topics
