Logging Pane (Interplay | MAM) Shortcuts
Keyboard shortcuts available when working in the Logging pane with Interplay MAM assets are listed in the following tables.
For shortcuts that you can use to control playback while logging, see
Media Pane Shortcuts.
Shortcuts for Working with Segments
Some of the following keystroke combinations work when the cursor is anywhere in the application and others work only when the cursor is located in the Logging pane. The Focus column in the table describes the focus required for each keystroke combination.
Shortcut | Description | Focus |
Ctrl+M (Windows and Macintosh) Command+M (Macintosh) | Create a new segment with the given In and Out marks | Global |
Ctrl+Shift+M | Create a new segment: Sets the In mark at the current playhead position but does not define an Out mark | Global |
Ctrl+Alt+M | Close the segment by setting an Out mark at current the playhead position | Global |
Tab key | Create a new segment with the given In and Out marks | Logging pane |
Ctrl+E | Split segment | Logging pane |
Ctrl+Z | Undo segment operation | Logging pane |
Ctrl+Y | Redo segment operation (see above) | Logging pane |
Insert key | Opens the Tag selector window to add a tag to a single segment or multiple segments at once (requires selecting multiple segments first using Ctrl+click or Shift+Click) | Logging pane |
Delete key (Windows) Backspace key (Macintosh) fn+Backspace key (MacBook) | Delete the selected segment or segments | Logging pane |
Up Arrow | Move to and select previous segment | Logging pane |
Down Arrow | Move to and select next segment | Logging pane |
Left Arrow | If the segment contains several properties, move to the previous property field If the segment contains only one property field, move to and select previous segment | Logging pane |
Right Arrow | If the segment contains several properties, move to the next property field If the segment contains only one property field, move to and select next segment | Logging pane |
Enter | Enter edit mode (text field) or open Tags selector window (tags field) | Logging pane |
Ctrl+Enter (Windows and Macintosh) Command+Enter (Macintosh) | Exit edit mode and save (when the focus is in a text field) | Logging pane |
Esc | Exit edit mode or close Tag selector window without saving | Logging pane |
Ctrl+S (Windows and Macintosh) Command+S (Macintosh) | Save segment and text without exiting edit mode | Logging pane |
F5 | Reload the content of the Logging pane | Logging pane |
Shortcuts for Working with Segment Text
The following table lists keyboard shortcuts that you use while working with segment text in edit mode.
“Edit mode” refers to the mode in which the text field of a segment is activated for text input (indicated by white field color).
Enter | Create a line break | Logging pane |
Up Arrow | Go to previous line | Logging pane |
Down Arrow | Go to next line | Logging pane |
Home or Pos1 (Windows) | Go to the beginning of the current line | Logging pane |
End (Windows) | Go to the end of the current line | Logging pane |
Ctrl+Shift+Up Arrow (Windows) Alt+Shift+Up Arrow (Macintosh) | Select previous paragraph | Logging pane |
Ctrl+Shift+Down Arrow (Windows) Alt+Shift+Down Arrow (Macintosh) | Select next paragraph | Logging pane |
Ctrl+Shift+Home (Windows) Ctrl+Shift+Pos1 (Windows) Command+Shift+Up Arrow (Macintosh) | Select text from the beginning to the current position | Logging pane |
Ctrl+Shift+End (Windows) Command+Shift+Down Arrow (Macintosh) | Select text from the current position to the end | Logging pane |
Shift+Left Arrow | Select text one character at a time moving backward | Logging pane |
Shift+Right Arrow | Select text one character at a time moving forward | Logging pane |
Ctrl+Shift+Left Arrow (Windows) Alt+Shift+Left Arrow (Macintosh) | Select text one word at a time moving backward | Logging pane |
Ctrl+Shift+Right Arrow (Windows) Alt+Shift+Right Arrow (Macintosh) | Select text one word at a time moving forward | Logging pane |
Shift+Up Arrow | Select text one line at a time moving upward | Logging pane |
Shift+Down Arrow | Select text one line at a time moving downward | Logging pane |
Ctrl+A (Windows) Command+A (Macintosh) | Select all text | Logging pane |
Delete key | Delete one letter or space forward | Logging pane |
Ctrl+Delete key | Delete one word forward | Logging pane |
Backspace key | Delete one letter or space backward | Logging pane |
Ctrl+Backspace key | Delete one word backward | Logging pane |
Ctrl+X | Cut selection | Logging pane |
Ctrl+C | Copy selection | Logging pane |
Ctrl+V | Paste selection | Logging pane |
Ctrl+Shift+D | Change the direction of the text (right-to-left or left-to-right) | Logging pane |
Shortcuts for Working with Segment Tags
The following table lists keyboard shortcuts that you use while working with segment tags.
Down Arrow | Set focus from search field into list of properties/tags selecting the first item in the (filtered) list | Tags selector window |
Enter | Open input control for the selected property | Tags selector window |
Esc | Close Tags selector window without inserting a tag | Tags selector window |
Enter | Insert selected value as tag | All input controls |
Alphabetic key | Navigate to the first element beginning with the typed letter | Thesaurus |
Tab | Autocomplete the typed word | Thesaurus |
Up Arrow | Select previous thesaurus entry | Thesaurus |
Down Arrow | Select next thesaurus entry | Thesaurus |
Right Arrow | Expand thesaurus node | Thesaurus |
Left Arrow | Collapse thesaurus node | Thesaurus |
Alphabetic key | Navigate to the first element beginning with the typed letter | Legal list |
Tab | Autocomplete the typed word | Legal list |
Up Arrow | Select previous list entry | Legal list |
Down Arrow | Select next list entry | Legal list |
Alphabetic key | Navigate to the first element beginning with the typed letter | Master data |
Up Arrow | Select previous list entry | Master data |
Down Arrow | Select next list entry | Master data |
Down Arrow | Opens the calendar control | Date or Date/Time field |
Spacebar | Insert current day | Calendar |
Ctrl+Up Arrow | Go to previous year | Calendar |
Ctrl+Down Arrow | Go to next year | Calendar |
Ctrl+Left Arrow | Go to previous month | Calendar |
Ctrl+Right Arrow | Go to next month | Calendar |
Up Arrow | Select the highlighted day a week ago | Calendar |
Down Arrow | Select the highlighted day next week | Calendar |
Left Arrow | Select previous day | Calendar |
Right Arrow | Select next day | Calendar |
Up Arrow | Increase the figures by one unit | Integer or Floating point field |
Down Arrow | Decrease the figures by one unit | Integer or Floating point field |
For more information on the Logging pane and its sections, see
Logging Interplay | MAM Assets.
