MediaCentral | UX User’s Guide : Using the Sequence Pane : Creating a Sequence : Rules for Creating a Script Sequence (Interplay | Production)
Keep in mind the following rules when creating a sequence that you want to associate with a story (referred to as a script sequence):
• When creating a new sequence that you want to associate with a story, first open the Sequence pane, then click the Open Sequence button to associate the sequence with the story.
• You cannot create a sequence for a story unless the story has a title (labeled Slug).
• If the Autoload Sequence option is enabled, you can create a sequence by opening the Sequence pane and either clicking the Open Sequence button or navigating to a story that already has a title.
• If the Autoload Sequence option is disabled, you must create a sequence by opening the Sequence pane and clicking the Open Sequence button.
• The sequence is not created in the Interplay Production database until you drag the first clip into the Sequence pane.
• You cannot send a sequence to playback until a video ID is present. See Associating a Video ID with a Script Sequence
*For more information on associating sequences with iNEWS stories, see Associating a Sequence with a Story.
Related Topics
Creating an Interplay | Production Sequence
