MediaCentral | UX User’s Guide : Using the Sequence Pane : Navigating in the Sequence Timeline
You can navigate through the Sequence Timeline simply by dragging the position indicator through the timecode bar, by clicking in the timecode bar, or by using the keyboard (for example, use the arrow keys to move one frame). For a complete list of keyboard shortcuts, see Sequence Pane Shortcuts.
Starting with MediaCentral UX v2.7, you can use Ctrl+click (Windows) or Command+click (Macintosh) to snap the position indicator to the closest cut of the enabled tracks. Do one of the following:
• Press and hold the Ctrl key, click in the timecode bar, and drag the position indicator to within a few pixels of the cut. The position indicator snaps to the cut.
• Move the mouse pointer within a few pixels of the cut, then press Ctrl+click.The position indicator snaps to the cut.
In both cases, the position indicator is located on the first frame after the cut.
Movement in the Sequence Timeline is synchronized with movement in the Media Timeline, so using controls in the Media pane moves the position indicator to the corresponding location in the Sequence Timeline. See Stepping Through Assets and Media Pane Shortcuts.
