MediaCentral | UX User’s Guide : Keyboard Shortcuts : Sequence Pane Shortcuts
Keyboard shortcuts available when working with the Sequence pane are listed in the following table. For more information on the pane and its sections, see Using the Sequence Pane.
Shortcut
Description
Focus
Ctrl+S (Windows) Command+S (Macintosh)
Save the sequence.
Sequence pane
Delete
Backspace (Windows)
Delete the selected segment.
Sequence pane
backslash (\)
Insert a video dissolve.
Sequence pane
Ctrl+E (Windows)
Command+E (Macintosh)
Split a segment into two segments
Sequence pane
Ctrl+Shift+X (Windows)
Command+Shift+X (Macintosh)
Extends a segment into another timing block.
Sequence pane
B
Perform an overwrite edit
Sequence pane
N
Perform a replace edit.
Sequence pane
Shift+drag
In an insert edit, override snap (sticky) points.
Sequence pane
Ctrl+click (Windows)
Command+click (Macintosh)
Snaps the position indicator to the closest cut of the enabled tracks.
• Press and hold the Ctrl key, click in the timecode bar, and drag the position indicator to within a few pixels of the cut.
• Move the mouse pointer within a few pixels of the cut, then press Ctrl+click..
Sequence pane
A
Move the position indicator to the previous segment in the Timeline. The position indicator moves to the first frame after the cut. In an Advanced sequence, the position indicator moves to the closest segment on an active track.
Sequence pane
S
Move the position indicator to the next segment in the Timeline. The position indicator moves to the first frame after the cut. In an Advanced sequence, the position indicator moves to the closest segment on an active track.
If you move the position indicator to the end of a sequence, the position indicator moves to the final (empty) frame.
Sequence pane
Up arrow
Zoom out of a sequence
Sequence pane
Down arrow
Zoom in to a sequence
Sequence pane
Alt+drag zoom handle
Enlarge or reduce one end of the zoom region (asymmetrical zoom)
Sequence pane
Right arrow
Move 1 frame forward
Sequence pane
Left arrow
Move 1 frame back
Sequence pane
Space bar
Play or pause play
Sequence pane
Ctrl+Z (Windows)
Command+Z (Macintosh)
Undo an action
Sequence pane
Ctrl+Y (Windows)
Command+Y (Macintosh)
Redo an action
Sequence pane
With trim indicators active
M
Trim the segment’s selected end by 10 frames earlier.
Sequence pane
comma (,)
Trim the segment’s selected end one frame earlier.
Sequence pane
period (.)
Trim the segment’s selected end one frame later.
Sequence pane
slash (/)
Trim the segment’s selected end 10 frames later.
Sequence pane
Shift+[
Trim from start of segment to the position indicator (trim top).
Sequence pane
Shift+]
Trim from the position indicator to the end of a segment (trim tail).
Sequence pane
With double-sided trim indicators active
Shift+M
Sequence pane
Shift+ comma (,)
Sequence pane
Shift+period (.)
Sequence pane
Shift+slash (/)
Sequence pane
