Previewing the Graphic in the Media Pane
You can preview the complete graphic in the MediaCentral UX Media viewer.
To load a graphic in the Media viewer:
In the Maestro Browser windows, click the Play button.
The graphic begins to render. New data from the graphic template is combined with the graphic itself and the combination is sent to the Maestro Render Server. The Play button shows the percentage of the graphic that is rendered until it is completely rendered and loaded in the Media viewer.
After the graphic is loaded, you can click the Play button in the Media viewer to view the graphic or drag the position indicator to scroll through the timeline.
In the following illustration, the Media pane shows a rendered graphic. Note that the design of the graphic might look different from the design of the graphic template.
The text on the tab of the Media pane refers to the Maestro timeline, where the graphic template behavior is defined.
