MediaCentral | UX User’s Guide : Using the Sequence Pane : Synchronizing Broadcast Graphics with a MediaCentral | UX Sequence : Using the Single Image Preview Setting
Starting with MediaCentral UX v2.10, the Maestro system settings include an option named “Single image preview.”
If this setting is enabled, and you initiate a preview of a graphic, the representative frame (which is marked in the Maestro Page editor for every template) will be used as a preview.This option provides a preview more quickly than a rendered preview and reduces bandwidth needs for the MediaCentral configuration.
If this setting is disabled, the full animation of a graphic is rendered and provided as a preview.
To enable single image preview:
1. Sign in to MediaCentral UX as an administrator.
2. Select System Settings from the Layout selector.
The System Settings layout opens.
3. In the Settings pane, select Maestro.
The Details pane displays the Maestro settings.
4. In the Render Server section, select “Single image preview” so that an orange check box appears.
5. Click Apply.
To disable the setting, click the orange check box so that it turns gray, then click Apply.
