Setting the Audio Mix
You can set the audio mix for an asset or for a sequence. For an asset, up to 24 tracks are monitored. You can select which tracks to monitor. For more information, see
Audio Monitoring for Assets and Basic Sequences. The audio mix is used for monitoring only.
See the
MediaCentral ReadMe for possible limitations on the number of tracks you can monitor.
To set the audio mix, do one of the following:
Select Mix Mode > Mono from the Audio Pane menu.
MediaCentral UX maps all audio tracks to a center pan, which creates a mono mixdown of all tracks. It outputs the resulting track to two identical channels.
Select Mix Mode > Stereo from the Audio Pane menu.
MediaCentral UX maps all audio tracks to two channels. The mix depends on your panning settings. See
Panning for Assets and Basic Sequences and
Panning for Advanced Sequences.
