MediaCentral | UX User’s Guide : Using Audio : Working with Audio Tracks in Basic Sequences
A basic sequence contains one audio track, which contains all source audio tracks. For a basic sequence, a single audio track is displayed in the Sequence Timeline. The Audio pane displays all source audio tracks.
You can add clips with up to 24 audio tracks to a sequence. All tracks are included in the saved sequence. The following illustration shows a basic sequence composed of a single multi-track clip. All tracks are displayed in the Audio pane.
You can perform the following tasks to edit audio for clips, subclips, or a basic sequence:
• You can select which tracks to monitor. See Audio Monitoring for Assets and Basic Sequences.
• You can set the mix as mono or stereo. See Setting the Audio Mix.
