MediaCentral | UX User’s Guide : Using Audio : The Audio Pane
The Audio Pane
The Audio pane provides you with controls for monitoring and adjusting audio levels.
The Audio pane is displayed in the Cut, Log, and Story layouts. You can drag the Audio pane to a different area if you prefer. If the Audio pane is not displayed, select Panes > Audio to open it.
Which controls are available depends on the type of asset and which mode is active in the Media pane. See the following topics:
• The Audio Pane for Asset Mode and Basic Sequences
• The Audio Pane for Advanced Sequences
