Caching Queues and Stories
To view queues and stories in offline mode, you must set them as Favorites before they can be cached locally and viewed when you do not have a connection to server (see
Working with Favorites).
You can delete a cache for a queue or story by deleting the item from the Favorites list.
To cache a queue or story in the Favorites list:
1. In the Launch pane, tap the Edit button, and tap to the left of the queue or story in the Favorites list you want to cache. You can select more than one queue or story at a time.
The queue or story displays a check mark next to the title.
2.
Tap the Cache button.
A progress bar indicates the status of the cache operation. To stop the cache operation, tap the Cancel button.
When the caching completes, a dialog box appears with the results of the operation.
3. Click OK.
To remove a cache from your device:
1. In the Launch pane, tap the Edit button, and then select the queue or story in the Favorites list you want to delete.
2.
Tap the Trash button.
The queue or story is removed from the Favorites list and the cache is deleted.
