Using Script Templates
Script templates are templates created by an administrator that allow you to insert predefined text and segments quickly into stories. For example, if a daily weather story in a show has a standard set of production cues and presenter instructions that are always the same, an administrator can create a script template that contains this information. The template can then be made available to MediaCentral UX mobile app users who can insert the template in new stories.
To use a script template:
1. Navigate to the existing story in the queue and open it.
2. Tap the Edit Story button.
3. Tap in the story body where you want to insert the template information.
4.
Tap the Script Template button.
The Select Script Template list opens.
5. Tap to select a script template.
The script template displays at the current cursor position.
