MediaCentral | UX User’s Guide : MediaCentral | UX Tablet Application for the iPad : Editing Stories : Ways of Saving Stories
You can save newly created stories or change existing stories by tapping the Edit Story button after modifying a story while in edit mode. A message appears asking you to confirm whether to save the changes. You can choose to save the story or exit edit mode without saving your changes.
Your story also is saved when the following occurs:
• You change to another app or send MediaCentral UX to the background by pressing the Home button.
• Your device goes to sleep due to Auto-Lock timeout.
• If you use a Smart Cover and close the cover, sending the device to sleep.
If you enable Autosave Stories in the MediaCentral UX Settings, you can save newly created stories or change existing stories in multiple ways:
• The app automatically saves a modified story when you tap on a different story in the queue.
• The app automatically saves a modified story when you tap the Presenter Mode button.
• The app automatically saves a modified story when you select an asset from the Interplay Production server to view.
• The app automatically saves a modified story when you change your role from Launch pane.
• The app automatically saves a modified story when you sign out of the app.
