MediaCentral | UX User’s Guide : Working with Assets : The Assets Pane : Navigating in the Assets Pane
As you browse through a database, the history of your navigation is retained in views. You can use the Back button or Forward button to display these views. You can also navigate to the next folder up in the database hierarchy by using the Up button. The name that appears in the Assets pane’s tab changes to reflect your location within the database you are viewing.
The following table lists the navigation buttons in the Assets pane.
Button
Description
Up button displays the contents of the next folder up in the database hierarchy. The button is inactive at the highest level of the hierarchy.
Back button toggles the current view to the previous view in the pane.
Forward button toggles the current view to the next view in the pane.
Refresh button refreshes the current view in the pane.
Close button closes the pane.
Pane Menu button opens a menu providing various options, including opening the help content related to the pane.
To expand a folder within the current view, do one of the following:
*Click the turn-down arrow to the left of a folder.
*Press the right arrow key.
To collapse a folder within the current view, do one of the following:
*Press the left arrow key.
To open a folder in a new view in the existing Assets pane:
*Double-click a folder.
To display a view you already displayed:
*Click the Forward button or the Back button.
To navigate to a folder up in the database hierarchy:
*Click the Up button.
For a list of all keyboard shortcuts you can use in the Assets pane, see Assets Pane Shortcuts.
