Removing a Graphic from a Sequence
You can remove a timed graphic (graphic segment) or an untimed graphic (placeholder) from a sequence. The graphic is also removed from the story.
To remove a graphic from a sequence:
Select the graphic segment or graphic placeholder and do one of the following:
- Right-click and select Delete.
- Click the Pane menu button and select Delete.
- Press the Delete key or the Backspace key.
