MediaCentral | UX User’s Guide : Using the Sequence Pane : Synchronizing Broadcast Graphics with a MediaCentral | UX Sequence : Opening a Graphic for Editing from a Sequence
From a MediaCentral UX sequence, you can open a graphic for editing in the Maestro Browser pane. After you save the graphic, changes are synchronized with the graphic in the sequence.
To open a graphic in the Maestro Browser, do one of the following:
*Double-click an untimed graphic placeholder or a timed graphic segment.
*Right-click an untimed graphic placeholder or a timed graphic segment and select Edit Graphic.
