Editing In and Out Points of a Graphic
You can edit the In and Out points of a timed graphic within a MediaCentral UX sequence, and the changes are synchronized with the graphic in the story. Changing the In or Out points of the graphic does not change the anchor position of the production cue in the story.
For a timed graphic, the position of the production cue (or anchor) in the iNEWS story text has no relation to the actual position of the graphic segment in the sequence.
You can also edit the In and Out points of the graphic in the Maestro Browser pane.
To edit the In or Out point of a timed graphic when it is displayed in a sequence, do one of the following:
Select the graphic segment in the sequence, and drag it to a new location.
If two graphic segments are on the same track, and you drag one towards the other, the graphic you are dragging stops when it reaches the other segment. There is no overlap of graphics on the same track.
Select the beginning or end of the graphic segment and drag it to a new location.
