MediaCentral | UX User’s Guide : Using the Sequence Pane : Opening a Sequence Associated with a Story
If you create a sequence through the Open Sequence button in the Queue/Story pane, the sequence is associated with the opened story as a script sequence (see Creating a Sequence).
You can select a user setting to automatically open a script sequence when you open the associated story.
To automatically open a script sequence with a story:
1. Select Home > User Settings.
2. Select iNEWS.
3. Select “Autoload Sequence.”
4. Click Apply.
To manually open a script sequence:
1. Open a story in the Queue/Story pane.
2. Open the Sequence pane.
3. Click the Open Sequence button.
The associated sequence opens in the Sequence pane and Media pane.
*After you associate a script sequence with a story, you cannot disassociate it. However, you can completely revise the sequence and rename it if necessary.
Related Topics
Creating a Sequence
Rules for Creating a Script Sequence (Interplay | Production)
