MediaCentral | UX User’s Guide : Using the Sequence Pane : Saving a Sequence
Saving a Sequence
If you save a sequence that is not associated with a story, the sequence is saved in the location you selected when you created the sequence in the Assets pane. To save another version of the sequence with a different name or in a different location, use the Save As feature. See Saving a Version of a Sequence.
If you are working with a sequence associated with a story, and you save the sequence through the Sequence pane, the story is automatically saved.
*If you save a story through the Story pane, you must manually save the sequence.
A MediaCentral UX administrator sets the location for storing a script sequence in the Interplay Production section of the MediaCentral UX System Settings. The default path is Projects/iNEWSsequences/date.
Saving a sequence automatically saves the markers contained in the sequence.
*You can move or copy a sequence in the Assets pane by using the Cut, Copy, and Paste commands.
To save a sequence, do one of the following:
*Click the Save button in the Sequence pane toolbar.
*Click the Pane Menu button and select Save Sequence.
*With focus in the Sequence pane, press Ctrl+S (Windows) or Command+S (Macintosh)
If you try to close a modified sequence without saving it, the Save Changes dialog box opens and asks if you want to save your changes.
