MediaCentral | UX User’s Guide : Using the Sequence Pane : Saving a Version of a Sequence
You can use the Save As feature to create and save a version of a sequence with a different name. You can also save the sequence in a different location. The new sequence is treated as a duplicate in the Interplay Production database, and can be edited independently from the original.
*The Save As feature is not supported for Interplay MAM sequences.
*You can move or copy a sequence in the Assets pane by using the Cut, Copy, and Paste commands.
To save a version of a sequence:
1. In the Sequence pane, click the Pane Menu button and select Save As.
The Select Interplay Folder dialog box opens.
2. Select the folder in which you want to save the sequence.
3. Rename the sequence.
If the sequence has the same name as a sequence in the selected folder, the Save button is grayed out. You need to rename the sequence or save it to a different folder.
4. Click Save.
The sequence is saved with the new name. This name is associated with the open sequence, and the next time you save the sequence, it will be saved with the new name.
To edit and save the sequence with its original name, you need to open the original sequence and save it with its original name. You cannot use the Save As feature to overwrite an already saved sequence.
