MediaCentral | UX User’s Guide : Building a Script : Segmenting Stories
Segmenting Stories
You can write a story in a single segment or divide it into multiple segments. The following illustration shows a story in a single segment.
You can use segments to time the text and integrate it with video, audio, and production cues. See Adding Media to a Story. Multiple timed segments are combined to form the overall story. The following illustration shows the same story as the one in the previous example, but written as a segmented story.
You can add or delete segments, split a segment in two, and rearrange segments within a story.
To add a segment to a story:
*Click in the segment marked NEW located at the bottom of the story and begin typing. See the previous illustration for an example.
To split a segment in two:
1. Position the cursor in the story where you want to split the text into two segments.
2. Do one of the following:
*Right-click and select Split Segment.
*Click the Pane Menu button and select Split Segment.
*Press Ctrl+] (Windows) or Command+] (Macintosh).
To rearrange segments in a story:
*Click the header bar of the segment you want to move and drag it up or down into its new location.
*When you rearrange segments, any production cues or machine control events in those segments are also moved and renumbered as needed.
To delete a segment and the text in the segment:
1. Select the segment.
2. Click the Pane Menu button located at the top right corner of the Queue/Story pane.
3. Select Delete Segment.
*Deleting the segment also deletes the text in the segment.
