MediaCentral | UX User’s Guide : Working with Video Media : Exporting an MP4 File
You can create an MP4 video and audio file from a clip or sequence loaded in the Media pane. The MP4 file is created from the resolution that is loaded in the Media pane.
• If a low-resolution version (default) is displayed, the low resolution is used.
• If a high-resolution version is displayed, the high resolution is used.
• If the STP target resolution is displayed, the displayed resolution is used.
Audio gain adjustments and mute controls as set in the Audio tool are used for the exported MP4 file.
The resulting MP4 file is the same video canvas size is the displayed version (for example, 1920x1080) encoded as H.264 with a stereo audio mixdown at 48 kHz per channel.
An Interplay Central administrator sets which user groups are allowed to export MP4 files through the Image Quality Settings of the System Settings Player tab. For more information, see Configuring Image Quality.
To export a clip or sequence as an MP4 file:
1. Load a clip or sequence in the Media pane (in either Asset mode or Output mode).
2. Click the Pane Menu button and select Export MP4.
When processing begins, a message from the Administrator is sent to you in the MediaCentral Messages pane. Another message is sent when the processing is complete. This message includes a link from which you can download the file.
