MediaCentral | UX User’s Guide : Keyboard Shortcuts : Queue/Story Pane Shortcuts
Keyboard shortcuts available when working in the Queue/Story pane are listed in the following table. Some keystroke combinations only work when the cursor is located in a certain section of the pane; the Focus column in the table specifies the section of the pane when that is the case. For more information on the pane and its sections, see The Queue/Story Pane.
Shortcut
Description
Focus
Ctrl+S
Save story
Queue/Story pane
Ctrl+E
Toggle the story’s edit lock on and off
Queue/Story pane
Shift+Left Arrow
Select text one character at a time moving backward
Story
Shift+Right Arrow
Select text one character at a time moving forward
Story
Shift+Up Arrow
Select text one line at a time moving upward
Story
Shift+Down Arrow
Select text one line at a time moving downward
Story
Ctrl+]
Split the segment
Story
Ctrl+X
Cut selection
Story
Ctrl+C
Copy selection
Queue/Story pane
Ctrl+V
Paste selection
Story
Ctrl+Z
Undo previous change
Queue/Story pane
Ctrl+Y
Redo previous change
Queue/Story pane
Ctrl+B
Set selected text to bold
Story
Ctrl+I
Italicize selected text
Story
Ctrl+U
Underline selected text
Story
Ctrl+Alt+P
Turn on Presenter Instruction mode or mark selected text as presenter instructions
Story
Alt+Insert
Insert production cue
Story
Ctrl+Alt+M
Mark selected text as machine control instructions
Cue List
Ctrl+Alt+C
Turn on Closed Captioning mode or mark selected text as closed captioning text
Story
Ctrl+Alt+N
Turn on Normal text mode or change selected text to normal font
Story
Ctrl+Alt+G
Create a Story Group
Queue/Story pane
Ctrl+Alt+V
Dissolve a Story Group
Queue/Story pane
Tab
Move to next form field
Story Form
Shift+Tab
Move to previous form field
Story Form
