MediaCentral | UX User’s Guide : Delivering Assets and Media : Delivering Assets and Media to a Remote Workgroup
If your organization is configured to include multiple Interplay Production workgroups, you can use MediaCentral UX to transfer assets and media from your current workgroup to another workgroup.
You can transfer assets and media from the Media pane, the Assets pane, or the Search pane.
• In the Media pane, you can transfer from Asset mode or from Output mode. You can transfer only the currently loaded asset. For clips, you can use the Deliver from Mark In to Mark Out feature. Sequences and subclips are not supported for delivery from Mark In to Mark Out.
• In the Assets pane or Search pane, you can select one asset or multiple assets.
You can track the status of the transfer in the Progress pane.
*By default, a Delivery provider is configured to run one job at a time. You can change this value by editing an .ini file. For more information, see the Interplay Delivery documentation.
To deliver to a remote workgroup from the Media pane:
1. Load an asset in either Asset mode or Output mode.
2. (Optional) If you want to deliver only part of a clip loaded in Asset mode, set In and Out marks. You cannot set In and Out marks on sequences or subclips.
3. Click the Pane Menu button and select Deliver To.
The Deliver To dialog box opens and displays the parameters of the selected profile.
4. From the Name list, select the Delivery profile that you want to use for the transfer.
Profiles are created by an Interplay Production administrator. The video format that will be delivered is displayed as Target Video Quality at the bottom of the dialog box.
5. (Optional) To deliver part of a clip, select Deliver from Mark In to Mark Out.
If you use this option, the Target Video Quality is taken from the Consolidate profile. See Understanding MediaCentral Delivery
6. Click Deliver To.
The job is submitted. You can view the status of the delivery in the Progress pane.
To deliver to a remote workgroup from the Assets pane or the Search pane:
1. Select one or more assets.
2. Do one of the following:
*Right-click a selected asset and select Deliver To.
*Click the Pane Menu button and select Deliver To.
3. From the Name list, select the Delivery profile that you want to use for the transfer.
4. Click Deliver To.
To view the status of the delivery:
*In the Progress pane, click the Pane Menu button and select Show Job Groups > Delivery.
*Delivery jobs that use Mark In to Mark Out use Interplay Consolidate and Interplay Production Services Automation to prepare the files for delivery. These jobs are displayed in the Interplay Media Services and Transfer Status tool. An Interplay Consolidate job is deleted after processing is complete. An Interplay Production Services Automation job persists.
Related Topics
Delivering Assets and Media to a Local Workgroup
