Assigning a Master Data Value
Master data, for example, data records about producers, actors, and so on, consist of multiple distinct values. These multiple values are represented by one master data value, when used for annotation. When you open a property of type master data, the Tags selector window initially shows an empty search box.
To assign a master data value:
1. Start typing the name of the value in the search box. MediaCentral UX searches the values starting with that letter. As you continue to type, MediaCentral UX continues to filter the list according to the letter you type.
2. Do one of the following:
Double-click the value.
Navigate down the list using the Down Arrow key until you reach the desired value and press Enter.
