MediaCentral | UX User’s Guide : Logging Interplay | MAM Assets : Annotating Text Fields
When editing text fields of a segment, most common features of text editing tools are available, such as inserting text at a selected position, marking text you want to overwrite, copying, pasting, and deleting, and so on.
You can use standard keyboard shortcuts to cut text or copy text to the system clipboard, or paste text from the system clipboard. This includes the ability to copy text from external sources such as documents or Web pages and to paste the text as segment annotation. The text is pasted without formatting. You can also do the reverse: copy segment text and paste it into an external source, such as Notepad.
*You can apply the cut, copy, and paste options only to properties of type “text”.
To edit text fields:
1. Do one of the following:
*Double-click the text field.
*Select a segment and press Enter.
The text field is set to edit mode which is indicated by a white background color.
2. If the field is still empty, type the text.
3. If the field already contains text, do one of the following:
*To add text, select the position at which you want to insert the text and start typing.
*To change text, mark and overwrite the existing text.
*To delete text, mark it and press the Delete or Backspace key.
4. Press Ctrl+Enter to leave edit mode and save your changes.
To cut text:
*Select the text and press Ctrl+X.
To copy text:
*Select the text and press Ctrl+C.
To paste text:
*Press Ctrl+V.
For a complete list of keyboard shortcuts, see Logging Pane (Interplay | MAM) Shortcuts.
