Resizing Segments (Gaps Allowed Mode)
When you want to resize segments in Gaps Allowed mode, select the frames you want to use as the new In or Out mark from the Media pane. You can extend the segment into a gap but you cannot extend the segment into another segment. This is only possible for strata that allow overlapping segments. See
Resizing Overlapping Segments.
To resize a segment:
1. Load an asset in the Logging pane and Media pane.
2. In the Logging pane, select the stratum in which you want to resize segments.
3. In the Media pane, select the same stratum to be displayed on the Media Timeline.
4. Select the segment to be resized.
The segment is highlighted in the Logging pane. In the Media pane the position indicator is set to the first frame of the segment.
5. To move the segment’s In mark, set the position indicator either within the segment or in the gap before the segment.
6. In the Logging pane, do one of the following:
Right-click the segment and select Set In.
Click the Pane Menu and select Set In.
The segment’s In mark is moved to the current position.
7. To move the segment’s Out mark, select the segment to be resized and set the position indicator either within the segment or in the gap after the segment.
8. In the Logging pane, do one of the following:
Right-click the segment and select Set Out.
Click the Pane Menu and select Set Out.
The segment’s Out mark is moved to the current position.
