Working with Stories
Using the mobile application, you can create a new story or edit an existing one. You can also change the title of story.
The system obtains an edit lock when you edit a story, which prevents other users from altering a story while you work on it. The edit lock applies only to the story body when you edit the body, and it applies only to the story title (the slug) when you edit the title. When you start a new story, the edit lock applies both to the story body and the story title. Saving and closing the story, or discarding your changes, releases the edit lock.
The MediaCentral UX mobile app can also be used with a Bluetooth keyboard.
Using the edit toolbar, you can cut, copy, and paste text, production cues, and segment breaks within the story while in edit mode.
To edit an existing story:
1. Tap in the Directory panel to navigate to an existing story in the queue and open it.
2.
Tap the Edit Story button.
The story opens in edit mode. An edit lock prevents others from changing the story while you edit.
3. Tap in the story to begin editing the text.
4. If you want to cut, copy, or paste text, do the following:
a. Tap and hold in the story where you want to edit the text.
The selection arrows and the edit toolbar display.
Edit mode, with the edit toolbar with Select All, Cut, Copy, and Paste buttons.
b. Tap and hold the selection arrows, and then drag them to highlight the text you want to edit or to place them at the location in the text where you want to perform an edit. You can cut, copy, and paste any text in the story, including production cues and segment breaks.
c. Tap the appropriate button in the edit toolbar.
5.
After you complete your modifications, tap the Save Story button to save the story. For more information, see
Ways of Saving Stories.
To add a new story:
1.
Tap the Add Story button.
The Edit Slug dialog box opens.
2. Type the title of your story, and tap OK.
A blank story is added to the current queue.
3. Tap the new story to open it, and then tap the Edit Story button.
When in edit mode (in the Script Editor), the application displays a virtual keyboard.
An edit lock prevents others from changing the story while you edit.The cursor moves to the blank title field.
4. (Optional) Enter any production cues or machine control instructions.
To edit the title (slug) of a story:
1. Navigate to an existing story in the queue and open it.
2. Tap Action overflow button.
The Action overflow button is not accessible in Edit mode.
3. Tap Edit Slug.
The Edit Slug dialog box opens, and the application displays a virtual keyboard.
4. Edit the story title, and then tap OK.
