MediaCentral | UX Administration Guide : User Management : Creating, Deleting, and Assigning Roles : Assigning Layouts to a Role
The Users layout includes a pane labeled Layouts. Layouts are defined by the MediaCentral UX plug-ins, so the list varies according to which plug-ins are installed. For example, installing the MAM Connector adds the Research layout. For a list of layouts, see Available Layouts: Administrators and Users. Administrators or users cannot create new layouts.
If you create a new role (as described in Creating and Deleting Roles), you need to assign at least one layout to the role. You can later assign additional layouts to the role. You assign layouts to a role, not to an individual user.
To assign a layout to a role:
*Click the Layouts pane, select the layout or layouts you want to assign to the role, and drag them to the Layouts section.
The layout is added to the Layouts list.
