MediaCentral | UX Administration Guide : User Management : Creating, Deleting, and Assigning Roles : Creating and Deleting Roles
The three default roles are Administrator, Media Logger, and Journalist. You can create additional roles and name them as you like. You cannot rename or delete the Administrator role.
*In Interplay Central v1.2.x and earlier, the names of roles were case-sensitive. As a result, the roles Journalist and JOURNALIST were treated as separate roles. In Interplay Central v1.3 and later, names of roles are no longer case-sensitive and cannot be duplicated. If you upgraded from a version earlier than Interplay Central v1.3, any duplicate roles were renamed, for example, JOURNALIST DUPLICATE_d8abb. You can rename this role to something more meaningful.
To create a role:
1. Select Users from the Layout selector.
2. Click the Roles pane.
3. Do one of the following:
*Click the Pane Menu button and select Create Role.
*Click the New Role button.
4. In the Details pane, type a name for the role.
This field is required.
5. (Optional) Type a description of the new role.
6. Select one of the following license types for the role:
- Advance
- Base
For more information on license types, see MediaCentral | UX Client Licensing.
7. Click the Layouts pane, select the layout or layouts you want to assign to the role, and drag them to the Layouts section.
The layout is added to the Layouts list.
8. Click Save or press Ctrl+S.
The role is added to the list in the Roles pane.
To delete a role:
3. Select the role you want to delete.
4. Do one of the following:
*Click the Pane Menu button and select Delete Role.
*Right-click and select Delete Role.
*Press the Backspace key or the Delete key.
A confirmation box asks if you want to delete the selected role.
5. Click Yes or press Enter.
The role is deleted.
