Editing Timecode or Duration Values
By default, Timecode and Duration fields are preformatted for different timecode types (PAL, NTSC). They also support pasting copied timecodes.
To enter a timecode or duration:
Type in the figures, including “0”, from right to left.
The control replaces the old figures starting with the frames value from right to left.
Highlight the timecode and press Ctrl+V to paste a copied timecode. If you paste an invalid timecode, the field shows a zero timecode.
