MediaCentral | UX User’s Guide : MediaCentral | UX Tablet Application for the iPad : Changing Roles
Changing Roles
Depending on your MediaCentral UX configuration and license, you might have more than one role with which you can work on your project. Each role has a set of layouts and permissions associated with it. If you have multiple roles available, you can change your current role from the Profile button in the Launch pane.
For more information about roles, see the Avid MediaCentral | UX Administrator’s Guide.
For more information about roles, see Creating, Deleting, and Assigning Roles.
To change your role, do the following:
1. Tap the Profile button, and then tap your new role in the Current Role section.
The Roles pane opens.
2. Tap a different role to select it.
The current role is marked by a check mark.
