MediaCentral | UX User’s Guide : MediaCentral | UX Tablet Application for the iPad : Customizing MediaCentral | UX Settings
You can modify some settings in MediaCentral UX.
To modify MediaCentral UX settings on the iPad:
1. On the Home screen, tap the Settings icon.
2. Select MediaCentral UX in the list of apps.
The following table provides information about general settings.
General Settings
Description
Version
For display purposes only, this value shows the currently installed version of the tablet app.
Logging
If set to On, MediaCentral UX keeps logs on session activities, which you can use to troubleshoot issues.
If you tap the Actions button, a Send Log option appears that lets you e-mail the logs directly to Avid. If the log file is more than 15 MB, you cannot send it directly. Use the iTunes File Sharing feature as described later in this topic.
If set to Off (default), logging and the Send Log option are disabled.
Logging Level
This setting determines how much information is logged if you enable logging. Options include: Verbose, Info, Warn, and Error.
Request Timeout
Options are intervals of 10, 20, or 30 seconds, 1 minute, or 2 minutes.
Keep me signed in
Set to On if you want MediaCentral UX to keep you signed in after you first sign in.
The following table provides information about the settings for editing.
Editing Settings
Description
Autosave Stories
If set to On, MediaCentral UX automatically saves a story if you navigate away from the modified story to other assets in the system. If set to Off, MediaCentral UX prompts you to save your modifications. The default setting is On.
The following table provides information about the settings for presenter mode.
Presenter Mode Settings
Description
Font Size
Options for presenter mode are 18, 22, 26, 32, and 38.
Normal Text
Normal text is the default text format of the story. Options are Black on White or White on Black.
Presenter Text
Presenter text is most often used for special instructions to presenters in scripts. Options are White on Black, Black on White, or Red on White.
Closed Captioning Text
Closed captioning is text sent to a closed caption encoder if your station uses such a device to broadcast text for the hearing-impaired. Options are White on Black, Black on White, or Green on White.
Skip Blank Stories
If set to On, presenter mode skips any stories that have no text or production cues.
To send log files to Avid:
1. Connect your device to a Macintosh computer.
2. Open iTunes and navigate to Device > Apps.
3. In the Apps list, select MediaCentral UX.
4. In the MediaCentral UX Documents list, select the Logs folder.
5. Click “Save to” or drag the folder to a location on your computer.
6. Zip the folder and send it to Avid as an e-mail attachment.
