MediaCentral | UX User’s Guide : Working with Assets : Working with Interplay | MAM Assets : Removing Asset References
You can remove basic sequences and other assets in the Interplay MAM Workspace. Note that this action removes the reference in the folder but does not delete the basic sequence or the asset itself.
To remove asset references from folders:
1. Select one or more assets.
2. Do one of the following:
*Right-click and select Delete.
*Click the Pane Menu button and select Delete.
A security prompt is displayed.
3. Click Yes.
If your credentials allow deleting assets, the asset references are deleted.
If you are not authorized to delete some of the selected assets or any assets, a message is displayed. After closing the message the folders that are released for deletion are deleted.
