Renaming Asset References
You can rename the reference of basic sequences and other assets in the Interplay MAM Workspace. Note that this action renames only the display name in the folder but not the basic sequence or the asset itself. To rename the asset or sequence, you must change its Main Title property in the Metadata pane.
Note also that the Media pane always shows the Main Title of an asset. If you only rename the reference of an asset in the Assets pane but not its Main Title property, you will see different names displayed for the same asset in the Assets and Media pane.
To rename an asset reference, do one of the following:
Select the asset, click the name of the asset, and type the new name.
Select the asset, press F2 (Windows) or Enter (Macintosh), and type the new name.
