MediaCentral | UX User’s Guide : Working with Assets : Working with Interplay | MAM Assets : Moving or Copying Assets
You can move or copy basic sequences and other assets in the Interplay MAM Workspace by using the Cut, Copy, and Paste commands, or drag and drop. This action does not move or copy the asset. You are moving and copying only the reference to the asset.
To move or copy an asset to another folder by using commands:
1. Select one or more assets.
2. Do one of the following:
*Click the Pane Menu button and select Cut, or right-click and select Cut.
*Click the Pane Menu button and select Copy, or right-click and select Copy.
3. Select the folder into which you want to move or copy the asset, right-click, and select Paste.
Valid assets are pasted into the folder, and assets that are not allowed as contents of the folder are not pasted. If there is already an asset with the same identifier in the folder, a message is displayed, and the asset is not pasted.
To copy an asset to another folder by using drag and drop:
2. Drag the selection to the name or icon of the folder into which you want to copy the assets.
The folder expands to show its contents and a green icon indicates if dropping is possible.
3. Release the mouse button.
Valid assets are pasted into the folder, and assets that are not allowed as contents of the folder are not pasted. If there is already an asset with the same identifier in the folder, a message is displayed, and the asset is not pasted. If your selection contained folders and individual assets, the folders and their contents are moved but the individual assets are copied.
