MediaCentral | UX User’s Guide : Working with Assets : Working with Interplay | MAM Assets : Duplicating a Basic Sequence
You can duplicate a sequence that is selected in the Assets pane. In doing so, you create a duplicate of the sequence in the Interplay MAM data base and add a reference to the sequence to the same folder in which the original sequence is located.
Your ability to duplicate a sequence depends on Interplay MAM user privileges and rules. The credentials you use to sign in to the Interplay MAM database must allow the creation of sequences.
To duplicate an Interplay MAM basic sequence:
1. In the Assets pane, navigate to the desired folder and select the basic sequence.
2. Do one of the following:
*Click the Pane Menu button and select Duplicate.
*Right-click and select Duplicate.
The Save As dialog box opens. The “Save sequence as” field shows the reference name of the sequence.
3. (Optional) Change the sequence name. You cannot delete the name.
4. Click Save.
A duplicate of the sequence is created and a reference is added to the folder open in the Assets pane. The provided name is set in the Main Title property of the sequence and as the name of the reference in the Assets pane. Your user name is set in the Created by and Modified by properties of the sequence.
The duplicate sequence is highlighted in the Assets pane but not opened in other panes.
