Deleting a Folder
You can delete folders from Interplay MAM Workspace in the Assets pane. If you delete a folder, all the references to media assets that it contains will also be deleted. Check whether you need the media asset references contained in a folder before you delete it.
Your ability to delete a folder depends on Interplay MAM user privileges: the folder permissions in Interplay MAM Workspace must allow the deletion of the selected folder. If the folder contains subfolders, you also must have delete permission for each subfolder.
To delete folders:
1. Select one or more folders.
2. Do one of the following:
Right-click and select Delete.
Click the Pane Menu button and select Delete.
A security prompt opens.
3. Click Yes.
If your credentials allow deleting folders the folders are deleted.
If you are not authorized to delete some of the selected folders or folders at all a message opens. After closing the message the folders that are released for deletion are deleted.
