Moving a Folder
You can move folders with their contents in the Interplay MAM Workspace by using the Cut and Paste commands or drag and drop. Note that you can move but cannot copy folders.
Your ability to move a folder depends on Interplay MAM rules: The folder permissions in Interplay MAM Workspace must allow moving the selected folder and adding it to the target folder.
To move a folder to another folder by using commands:
1. Select one or more folders.
2. Do one of the following:
Click the Pane Menu button and select Cut.
Right-click and select Cut.
3. Select the folder into which you want to move the folder, right-click, and select Paste.
The Move Folder message box opens.
4. Do one of the following:
Click Yes to move the folder including its contents.
Click No to keep the folder including its contents in its original location.
If you selected both a folder and individual assets, only the individual assets are moved.
Click the X button to cancel the move operation.
To move a folder by using drag and drop:
2. Drag the selection to the folder into which you want to move the folder.
The folder expands to show its contents and a green icon indicates if dropping is possible.
3. Release the mouse button.
